What is the most efficient way to program these modules for mass with specific uart parameters? We want to reduce the steps in mass production. If the modules are shipped with 115200, the hos t MCU won't be able to communicate with the module as the host lacks the run time change for baudrate.
Se
The EZ-Serial FW source code is not avaliable for customers. If you need a customized EZ-Serial FW, please contact your local FAE/Marketing for help.
