Hello Cypress IoT team.
[Environment]
- WICED Studio version: 6.4
- Compiler: MinGW-w64
- Target OS: Windows 10
[Background]
To optimize MBT tool for our environment, we would like to build mbt.cpp in the following directory.
WICED-Studio-6.4\wiced_tools\mbt\mbt.cpp
However, I encountered some errors when building.
== Error Log ==
$g++ -o mbt.exe mbt_com.cpp mbt_usb.cpp mbt.cpp
mbt_com.cpp:17:46: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
static char* _stopBits[] = { "1", "1.5", "2" };
mbt_com.cpp: In destructor 'virtual ComHelper::~ComHelper()':
mbt_com.cpp:80:39: error: no matching function for call to 'ComHelper::~ComHelper()'
TransportHelper::~TransportHelper();
In file included from mbt_com.h:13,
from mbt_com.cpp:14:
mbt.h:17:13: note: candidate: 'virtual TransportHelper::~TransportHelper()'
virtual ~TransportHelper() {};
mbt.h:17:13: note: candidate expects 1 argument, 0 provided
mbt_com.cpp: In member function 'virtual BOOL ComHelper::OpenPort(char*)':
mbt_com.cpp:126:84: error: cast from 'HANDLE' {aka 'void*'} to 'DWORD' {aka 'long unsigned int'} loses precision [-fpermissive]
Logger.DebugOut("OpenPort Overlap Event Handle=%x\n", (DWORD)m_OverlapRead.hEvent);
mbt_com.cpp:128:85: error: cast from 'HANDLE' {aka 'void*'} to 'DWORD' {aka 'long unsigned int'} loses precision [-fpermissive]
Logger.DebugOut("OpenPort Overlap Event Handle=%x\n", (DWORD)m_OverlapWrite.hEvent);
mbt.cpp: In function 'int execute_connectionless_dut_loopback_mode(char*)':
mbt.cpp:832:9: error: 'scanf_s' was not declared in this scope
scanf_s("%x",&bd
mbt.cpp:832:9: note: suggested alternative: 'sscanf_s'
scanf_s("%x",&bd
sscanf_s
mbt.cpp:840:5: error: 'scanf_s' was not declared in this scope
scanf_s("%x", <_addr);
mbt.cpp:840:5: note: suggested alternative: 'sscanf_s'
sscanf_s
[Need Help]
Could you tell us the cypress reference way to build MBT?
Yoshinori
Hi Yoshinori,
Are you trying to change source code of MBT tool?
We strongly suggest customers not to modify source code of in-built tools such as MBT, chipload. I am afraid I won't be able to help you with any advancements with the MBT source code
However, I will suggest you to get in touch with your local Cypress team regarding this request.
Hi Yoshinori,
