Hello Cypress Community! I have some problems with low power application. I use CYW90719Q40EVB-01.
Here I will explain it in few steps:
1. I generated a BLE application ("T-Shirt") using WICED Bluetooth Designer.
2. Edited the source code according to "low_power_sensor" demo of WICED Studio
3. I run it.
4. When timeout occurs, It successfully goes to sleep.
But when it starts sleeping, it accidentaly wakes up again, although I don't call interrupts.
My question is WHAT CAN BE THE CAUSE? WHO HAD SUCH PROBLEM, PLESE HELP!
P.S. I have attached the source code just in case...
Bakhman.
- low power
Thanks for your interest OwenZ_26 !
Even when i disabled all advertisements the behaviour was the same.
But fortunately I found the problem. I should have changed the value of "Interval of random address refreshing" in "wiced_bt_cfg.c"
/* LE Address Resolution Database Settings */
from
.rpa_refresh_timeout = WICED_BT_CFG_DEFAULT_RANDOM_ADDRESS_CHANGE_TIMEOUT,
to
.rpa_refresh_timeout = WICED_BT_CFG_DEFAULT_RANDOM_ADDRESS_NEVER_CHANGE,
This parameter made the application wake up again and again!
