MiRo_263836
100 replies posted 50 likes received 50 replies posted
I am targeting the CYW20719
Take a look at /20706-A2_Bluetooth/apps/snip/bt/hci_handsfree
* Features demonstrated
*  - WICED BT Handsfree (Device) APIs
*  - Handling of the UART WICED protocol
*  - SDP configuration
*  - Setting of the Local Bluetooth Device address from the host MCU
* On startup this demo:
*  - Initializes the Bluetooth sub system
*  - Receive NVRAM information from the host
* Application Instructions
*  - Connect a PC terminal to the serial port of the WICED Eval board.
*  - Start ClientControl application.
*  - Select the COM port assigned to the WICED Eval board.
*  - Download the application
* BR/EDR
* - To find BR/EDR devices: Click on "Start BR/EDR Discovery"
* Handsfree Connection
* - To create handsfree connection to remote AG device , choose the bluetooth
*   address of the remote AG device from the BR/EDR combo box
* - Click "Connect" button under Handsfree
* - OR Put the device in discoverable and connectable mode and serach for the device from AG device and connect
* - The following HF operations can be performed using the client control application
*      Connect / Disconnect HF or SCO connection
*      Answer / Hangup the call
*      Dial / Redial the number
*      Control Held call (ex. release all held calls, add held to conversion etc.)
*      Mic / Speaker gain control
MiRo_263836
I was wrong;  The target is the CYW20706
* BR/EDR
Thank you. That looks like what I need.  Once I switched to the correct part in WICED, it cleared thing up.
No problem.  Note that HFP is not supported under the 20719.
