We are trying to take advantage of the Bt 5.0 feature of connecting to two audio sinks. We are using CYW920719Q40EVB-01. We tried modifying the AV Source piece of the watch example, but on the second connection call we get an "out of resources" error. This error occurs in a hidden function named "wiced_bt_avdt_connect_req". We are worried that the software is limiting us to one connection. Is it possible to make two separate processes that each manage their own AVRC connection?
As per the profile support in CYW20719, only single AVRC connection can be made at a time.
Anjana
A2DP Sink is not supported on the 20719: WICED Bluetooth Software Features
The CYW20706 would be a better choice: A2DP Sink Example on CYW20706
We are not using 20719 as a sink. It is meant to be connected to a computer and act as an audio source for multiple devices.
Anjana
