KeTa_1341526
10 solutions authored 5 solutions authored 100 replies posted
CYBT-333047-02 has obtained FCC / ISED / MIC / CE regulatory certification.
RF Regulatory Certifications for CYBT-333032-02/CYBT-333047-02 EZ-BT™ XR Module - KBA225653
And the qualified Antenna for CYBT-3330xx-02 are:
Q1.
Do I need to get regulatory certification again if I use something other than this antenna?
Please tell me in each of the following cases.
* I also refer to the following, but I would like to confirm each regulation.
FAQ for BLE and Regulatory Certifications with EZ-BLE modules - KBA213976
  Case-1) Dipole antenna of 2.2 dBi or less or the same value
                - FCC : yes or no ?
                - ISED : yes or no ?
                - MIC : yes or no ?
                - CE : yes or no ?
  Case-2) 2.2dBi or more dipole antenna
                - FCC : yes or no ?
                - MIC : yes or no ?
                - CE : yes or no ?
  Case-3) Antenna of a different type from dipole
                - FCC : yes or no ?
                - MIC : yes or no ?
                - CE : yes or no ?
Q2.
If you need to obtain regulatory certification again, you will need the following data.
Can you provide it?
The information contained in the data sheet is insufficient and the image is not clear.
- Block Diagram
- Schematic
- BOM list
Best reagrds,
Takahashi
SheetalJ
Hi Takahashi,
I think help article FAQ for BLE and Regulatory Certifications with EZ-BLE modules - KBA213976 answers most of your queries. Let me highlight them here again:
Q1-A:
The module is designed to work with a standard 2.2 dBi dipole antenna. Any antenna of equivalent or less gain can be used without additional application and testing for FCC/IC regulations. The following table details approved antenna for the CYBLE-202007-01 module antennas.
ManufacturerPart NumberGain
AntenovaB4844-012.2 dBi
RFlinkRF21C01228A2.0 dBi
PulseW10302.0 dBi
You do not need to redo the Bluetooth SIG certification with a new antenna as the RF-PHY test in Bluetooth SIG certification is not related to antenna gain.
Q2-A:
Please find this information (schematics, layout, gerber, BOM) here:
https://www.cypress.com/documentation/development-kitsboards/cybt-333047-eval-ez-bt-module-arduino-e...
SheetalJ
Hi Takahashi,
Q1-A:
PulseW10302.0 dBi
Q2-A:
>Q2-A:
This is the module evaluation board information.
The information I need is the schematic of Module (CYBT-333047-02), Block diagram, and BOM list.
Takahashi
Hello Takahashi,
For CYBT-333047-02, I would suggest you to contact your local Cypress team. We can follow this request in a SFDC case probably.
Sheetal
