In our existing project we use CYBT-353027-02 module and WICED Studio 6.4. The CYBT module is running in embedded mode. The module is connected to a host CPU via UART. CYBT firmware update is done via UART, using correspondent minidriver.
Question: after loading minidriver to RAM we execute HCI_FLASH_ERASE command (0x01, 0xCE, 0xFF, 0x04, 0x00, 0x00, 0x00, 0xFF). Is it really necessary? Our goal is to keep application data in CYBT untouched after firmware upgrade, i.e. to keep link keys, BT MAC address and so on. Is it possible?
WICED Studio Bluetooth
- wiced sdk
Hello @kf
My understanding is that for you for your second time programming / upgrading firmware , you want to skip chip erase to save volatile data. In that case, yes you can skip chip erase.
Please go through the details of full download & upgrade download scenarios details from here: https://infineon.github.io/btsdk-docs/BT-SDK/AIROC-HCI-Firmware-Download.pdf
Anjana
Hello @kf
Anjana
Hello Anjana,
Thank you for providing updated document.
Actually, in our current update procedure we are not able to distinguish between "Full Download" and "Upgrade Download". However, during very first programming at factory we add one more step where device-specific MAC address gets stored in flash.
Therefore, my question is: is it safe to skip erasing the complete flash even in "Full Download" scenario?
And one more question: do I understand it right that 'CHIP_ERASE 0xFF000000' will erase the whole external flash of CYBT-353027-02, while 'CHIP_ERASE 0xFCBEEEEF' will only erase DS1 and DS2 sections (I'm referring to Table 1 in 002-19289 Rev. *H document)?
Konstantin
Update:
As said in the document, "If it is desirable to preserve some data in flash and only erase sectors that will be written, CHIP_ERASE may be skipped". You can use SECTOR_ERASE command for erasing specific sectors alone.
A special value of EF EE BE FC (0xFCBEEEEF) is used to signal “use the lowest valid non-volatile memory range”.
Meaning, that whichever is the lowest non-volatile memory, in this case between on-chip and off-chip flash, the command will select it and erase. And 0x500000 would be the start of on-chip flash when supported and 0xFF000000 would be the start of off-chip flash.
FYI.
https://github.com/Infineon/btsdk-docs/blob/master/docs/BT-SDK/AIROC-HCI-Control-Protocol.pdf
https://github.com/Infineon/btsdk-docs/blob/master/docs/BT-SDK/AIROC-HCI-Firmware-Download.pdf
