PaYe_4603801
Level 4
Level 4
5 likes given Welcome! 25 replies posted
For example, I didn't find the description of type wiced_platform_button_config_t.
Probably there are a lot of types/functions that aren't documented.
Pavel.
Hi PaYe_4603801
You can find the definition of these in wiced_platform.c which is located in baselib folder inside wiced_btsdk.
I would suggest you to utilize search functionality (do ctrl+H). Take C/C++ search tab in it, set the scope and click on search.
After the search just right click on the structure/function name and open the declaration.
See the attached screenshot.
-Dheeraj
PaYe_4603801
Level 4
Level 4
... also function wiced_platform_register_button_callback.
Does exist some criteria, according to which some items from SDK are documented, others - NOT.
Hi PaYe_4603801
-Dheeraj
