Hello
1.
I was previously taught by the thread below how to use CYBT-343026-01 in HCI mode.
https://community.cypress.com/t5/WICED-Studio-Bluetooth/About-the-WICED-HCI-protocol/m-p/57884#M1051
When I used the Inquiry command to search for peripheral devices after booting in HCI mode, no Inquiry result was returned.
Do I need to make any other settings after booting?
(I can find multiple devices by running the Inquiry command in EZ-Serial mode.)
2.
I also found the description However you may need to program it initially with firmware / patches. In the thread below.
Also, does this have anything to do with the behavior in Question 1?
Isn't it possible to use standard HCI just by switching to HCI mode by operating SPI_MOSI and CTS at reset?
Is it possible to provide firmware / patches for Android?
Best Regards
Hayato
WICED Studio Bluetooth
Duplicated with Solved: Initial settings when using HCI mode - Cypress Developer Community
The community had been experienced some problem(certain threads not published immediately) due to migration, sorry for the convenience.
