jama_4535901
10 sign-ins 5 sign-ins 25 replies posted
Please
Can you help me?
I want the CYBT-213043-MESH board with the code: Mesh_Snip_213043MESH.mesh_vendor_specific_app
send a message ( "0x01,0x02,0x03,0x04,0x05,0x06") to CYBT-213043-MESH  board with code: Mesh_Snip_213043MESH.mesh_provision_client / mesh_vendor_client.c or other CYBT-213043-MESH  board with code: mesh_vendor_specific_app
But I don't want to use the function: mesh_vendor_server_send_data (wiced_bt_mesh_create_reply_event (p_event), MESH_VENDOR_OPCODE3, p_buffer, data_len +1);
Now I want to use the function: wiced_bt_mesh_create_event
I want to know, these are the lines that I should use ?:
p_event = wiced_bt_mesh_create_event (element_idx, company_id, model_id, dst, app_key_idx);
    if (p_event == NULL)
        WICED_BT_TRACE ("app_proc_rx_cmd: no mem \ n");
        return WICED_TRUE;
    mesh_vendor_server_send_data (p_event, cmd_opcode, p_data + 6, length - 6);
how can i use this function wiced_bt_mesh_create_event
i don't understand what it is: element_idx, company_id, model_id, dst, app_key_idx
Please
Can you help me?
DheerajPK_41
mesh_vendor_specific_app is a sample implementation of mesh vendor model.
Please check wiced_bt_mesh_event.h for the detailed description about mesh event APIs and usage.
I'm Afraid, I did not understand the below statement.
"But I don't want to use the function: mesh_vendor_server_send_data (wiced_bt_mesh_create_reply_event (p_event), MESH_VENDOR_OPCODE3, p_buffer, data_len +1);"    ->
mesh_vendor_server_send_data() wrapper function used to send the VS data and status messages between VS client and server.
I would suggest you to go through the below documents to understand the mesh architecture and basics.
-Dheeraj
DheerajPK_41
-Dheeraj
