Hi Cypress
We use CYW920706WCDEVAL EVB board for RX test , I follow attach file for Bluetooth EDR sensitivity test ( page 3 ) by BlueTool , When I input Write_Receive_Only command then I how to do for the next step ( Sent the waveform then wait respond receive value or input read counter value command . ) , Thank !!
Did you perform the below steps before you set the device into Test Mode?
1) Reset
2) Set_Event_Filter
3) Write_Scan_Enable
4) Enable_Device_Under_Test_Mode
Has your test equipment make a connection to the DUT already? For Rx testing, your test equipment should send the waveform instead. From the picture above, the DUT is listening on 2402MHz.
Alternatively, you can set the DUT into testmode. Then the test equipment can do a full test suite on the DUT.
Hi Cypress
Yes, We have connect DUT(RX) with IQxel(TX) , We can work in BlueTool with two Cypress sample in 0:Vendor-specific Commands (0 key)-Tx_test and RX_Test , but it still can't work in Cypress(RX) with IQxel(TX) as blew
1) Reset
2) Set_Event_Filter
