iats_3604431
     I am trying to set  PWM  generator to 7.5HZ.
     i can set PWM generator to [integer] HZ, like 7HZ or 8HZ... by set PWM_INP_CLK_IN_HZ and PWM_FREQ_IN_HZ,
     but the PWM_FREQ_IN_HZ can only set integer.
     Does everybody know how to set PWM generator to 7.5HZ?
MuraliR_36
250 sign-ins 250 replies posted 100 solutions authored
The parameters PWM_INP_CLK_IN_HZ and PWM_FREQ_IN_HZ are passed into the wiced_hal_pwm_get_params() API. This API is defined to take only integer values as parameters. So even if you define PWM_INP_CLK_IN_HZ and PWM_FREQ_IN_HZ as floating point values, it would get type-casted to an integer value during compilation.
MuraliR_36
Hi MuralR_36,
          Thanks for your reply.
