Jul 09, 2020
01:47 AM
Jul 09, 2020
01:47 AM
Now, I can configure the GPIO successful, but I don't know how to put the desired frequency that come from ACLK. Can you give me some advice? Looking forward to your reply! how to put aclk_output_frequency to GPIO.jpg Have a good day to you!
- aclk
- cyw20719b1
- gpio
01:55 AM
Jul 09, 2020
01:55 AM
Hi qzy_4727816,
If you look at the parameters of API wiced_hal_aclk_enable(), first parameter is to set the desired output frequency. I would again suggest you to look at /20719-B1_Bluetooth/apps/snip/hal/pwm/hal_pwm.c. Here a GPIO is seletced & configured.
Desired frequency and other parameters are defined.
If you right click on the function name and select 'Open Declaration', you will get more details about the function and its parameters.
