LixinD_46
Hi
WICED platform: 6.0.0.43
Chip Platform: CYW20719-B1
Issue Description:
When invoke the wiced_bt_dev_get_bonded_devices() API, the always return 0x1FA7 error code, and the input value of *p_num_devices didn't been set to 0 even failed.
So doesn't this API really supported? If it's supported, how to fix this issue.
Dudley
JacobT_81
250 likes received 100 likes received 50 likes received
It appears that this API is only available when using a version of the WICED stack that handles key storage on your behalf. However, currently all the sample apps handle key storage using the NVRAM APIs. In order to read out the list of bonded devices, you will need to read out the NVRAM that is storing the keys+BD_ADDRs (as the apps do on every boot to load in the key data).
It's not clear why these APIs are exposed if they are not supported. I will look into it further.
Jacob
ShengY_96
Welcome! 25 solutions authored 10 solutions authored
Hi Dudley
Issue can been reproduce in my side. Per the wiced_result_t's comments, the eroor code:8103 meas: "Unsupported function".
Hi Jacob  jact
Could you please share some comments.
Jenson
JacobT_81
Jacob
Lavanya
25 sign-ins 5 questions asked 10 replies posted
Is this still not supported. We need to know howmany devices are connected bonded.
wiced_bt_dev_get_bonded_devices seems always returning unsupported. Can some one give us solution how to find the bonded devices.
