Studio Bluetooth
shga_3724686
New Contributor
Hello!
     I want to send LMP_test_activate PDU from Master to Slave, is there any way?
     Is there a corresponding HCI command that can implemente this?
     Thanks!
Owen_Zhang123
I checked the bluetooth spec, there isn't such HCI command for the device to send LMP_test_active PDU. The LM layer is also not open to the customer.
Owen_Zhang123
You may send HCI comand: Enable_Device_Under_Test_Mode. It is a HCI command and can support by the device.
shga_3724686
New Contributor
     Thanks!
     I know this command. But my purpose is to control the local device to send LMP_test_activate PDU to the remote device. Is there any feasible way?
Owen_Zhang123
