veb_3529051
I recently brought the CYW20719 EVAL kit, and i would like to do a RF Rx test, can you help me how to do a Radio Rx test?  whether i'll get the transmitted bit pattern on any one of the I/O Pin else i need to read any register values, if yes what are the HCI commands that i should use.
AnjanaM_61
10 questions asked 5 comments on KBA First comment on KBA
You can use our Manufacturing test tool for the test.
Please have a look at Manufacturing-Bluetooth-Test-Tool.pdf in the doc folder of WICED studio.
Refer ReadMe.txt of mbt in WICED studio ( Path : /20719-B1_Bluetooth/wiced_tools/mbt )
Note: You have to run the MBT using command prompt from the original folder location (C:\Users\....\Documents\WICED-Studio-6.2\wiced_tools\mbt)
The test procedure and commands are described in the ReadMe.txt
Thanks & Regards,
Anjana
AnjanaM_61
Thanks & Regards,
Anjana
Thanks for the response
