Development environment:
Windows 8.1 pro
Platform: CYBT-423028-02
IDE: Wiced Studio 6.2.1
Just as an example :
Created service A
It has 2 characteristics B and C
B characteristic has Read and Write property n permission
C characteristic has Read and Notify property n permission
We have developed a demo code and created a characteristic(C) of one of the services(A) with "Notify" property.
Once the peer device writes into the client configuration of (C), I get the 0x1000 for notification.
But when we use the same characteristic to send the notification value, A peer device is not getting any notification. Please tell me which attr handle should be used to send the notification to peer device, please share the example.
wiced_bt_gatt_status_t wiced_bt_gatt_send_notification (uint16_t conn_id, uint16_t attr_handle, uint16_t val_len, uint8_t *p_val );
conn_id = connected device's id
attr_handle = (Characteristic C )CLIENT_CONFIGURATION , handle
val_len = length of the actual data to be shared with a connected device
p_val = Notification value
Please note we have followed the steps from the "demo.sensor" project, but it doesn't work in our code.
So please provide me the proper example of it.
Found the issue.. the connection ID was updated wrong.. Thanks anyways.
