Collaborative Coexistence is written in CYW20706
Datasheet P.9.
But I can't find that How to use? I want to link third
party wlan device.
but, There is no explanation anything.
I find only this function in API.
void wiced_bt_coex_enable | ( | void | ) |
but there is no parameter. no description. no pin
settings.
Please teach me. How to use it?
Thankyou.
The CYW20706 supports the proprietary Cypress Global Coexistence Interface (GCI) which is a 2-wire interface. This can be used with other Cypress devices and not with 3rd party devices. wiced_bt_enable_coex() is used to enable GCI on CYW20706. It uses just two pins: SECI_IN and SECI_OUT. For more details on coex, refer to the datasheet of CYW20706.
I am afraid you cannot use coex between CYW20706 and a 3rd party device.
