Aug 16, 2017
11:04 PM
Aug 16, 2017
11:04 PM
The current default power value is 9 ~ 10dBm. I want to set this value to 0dBm.
Is there an API that can be changed in the source code?@
- teaser
07:42 PM
Aug 21, 2017
07:42 PM
It means that we have separate dedicated configuration files (with .HCD extension) for Class 2 and Class 1 operations. The latter is obviously configured for Tx output up to 10dBm.
Are you setting the device into test mode to measure the Tx power via a BT tester?
