David_Zhang
100 replies posted First solution authored 50 replies posted
hi  Cypress:
          when we use cyw20706 to receive the i2s smart voice, how to connect the hardware, there are some noise in I2S clk/dio,show as below;  do you have any advice?
Owen_Zhang123
500 solutions authored 250 sign-ins 1000 replies posted
It seems you missed the waveform. The I2S/PCM interface for CYW20706 is fixed.
If the CYW20706 act as a I2S slave, the clk is supplied by the master device. You may check the master side for the reason.
Owen_Zhang123
