LJYe_2922526
25 likes received 10 likes received 5 likes given
Are the host and dev wakeup lines used during firmware download? Are they active high or low? I'm using 20706. Thanks!
If you are referring to the DEV_WAKE and HOST_WAKE lines, no, they are not used during firmware download. If you are planning to use them in your application, you can configure the pins as either ACTIVE HIGH or LOW.
