I'm using the HCI Uart to send and receive commands from my host computer to the CYBT module.
I also managed to see Trace output generated by "WICED_BT_TRACE" via BTSpy on PUART.
However, when I enable HCI Trace I will receive alot of HCI Trace Events on my HCI Uart. But I can't interprete these data.
I would like to let BTSpy interprete those events. How can I forward those HCI Trace Events to the PUART? Will BTSpy be capable of interpreting the data?
Alex
Hi @aglier ,
Thanks for clarifying. The HCI traces (between embedded host and controller) can be routed only through HCI UART and not PUART. Since you need these traces only for debugging, we recommend you to attach Client control to the HCI UART and later you can use BTSpy to listen to the traces. Steps needed in your application to add support for Btspy is detailed below.
https://github.com/Infineon/CypressAcademy_BT101_Files/blob/master/PDFs/WBT101-05-Debugging.pdf
Bragadeesh
Bragadeesh
Hi @aglier ,
Could you please provide a block diagram of your setup?
-> Are you using your device in controller only mode or embedded mode? What commands are you sending using HCI UART? Is it HCI commands or WICED HCI commands? Are you interfacing the CYBT module to Client Control?
-> Can you please clarify this? PUART can not be connected to BtSPY. We can only connect HCI UART to Btspy. You might have set the wiced_set_debug_uart API with WICED_ROUTE_DEBUG_TO_WICED_UART. PUART is only used to send WICED_BT_TRACE messages and normal UART messages.
However, when I enable HCI Trace I will receive alot of HCI Trace Events on my HCI Uart. But I can't interprete these data. I would like to let BTSpy interprete those events. How can I forward those HCI Trace Events to the PUART? Will BTSpy be capable of interpreting the data?
-> Could you please clarify how you enabled HCI trace? Are you referring to the HCI messages between host and controller? We can view the HCI traces only through BTspy through HCI UART and not through PUART.
Please go through the below document . It explains how to route HCI trace messages to BtSpy via HCI UART.
Bragadeesh
Hi @BragadeeshV ,
I will try to explain my setup in more detail:
I don't use ClientControl.exe.
I wrote my own application that sends WICED HCI Protocol over HCI Uart to an CYBT-343026 EVAL board.
I wrote my own embedded application using Modus Toolbox.
The current configuration for Wiced trace is set by:
wiced_set_debug_uart(WICED_ROUTE_DEBUG_TO_PUART);
Which also works as expected. I can see all output from WICED_BT_TRACE("...") on the PUART by using a Serial Terminal.
My question is about the WICED Protocol Event: Hci Trace
For my understanding, this is what is send between the module internal controller and the bluetooth stack.
I would like to read what is going on there.
How can I interprete those? Do I have to do this "by hand" using the Bluetooth Core Spec or is there a software that might be able to interprete this (like BTSpy etc.)?
I hope this explains it a bit.
Alex
Hi @aglier ,
Bragadeesh
Bragadeesh
Thank you. That helped me out.
