I have used the latest Firmware 1.2.27 (for CYBT-343026-01) below to verify the operation of BLE GAP Central.
https://www.cypress.com/documentation/software-and-drivers/ez-serial-ez-ble-module-firmware-platform
I refer to [3.5 GAP Central Examples] in the User Guide.
I have confirmed the operation of [Example 2: Start 5-second active scan with duplicate filtering enabled], but the scan response packet reports the same data as advertise.
@E,0062,S,R=00,A=EF00028B78FD,T=01,S=DB,B=00,D=020106110700A10C2000089A9EE21115A13333336507FF310100000000
@E,0062,S,R=04,A=EF00028B78FD,T=01,S=DA,B=00,D=020106110700A10C2000089A9EE21115A13333336507FF310100000000
For the environment we are checking, we have prepared two CYBT-343026-01. (One is Central, the other is Peripheral)
Since Factory reset (/ RFAC) is performed, the settings are in the initial state.
Are there any other settings you need?
TK
We have confirmed that the problem is caused by the ez-serial fw. The problem will be fixed in the next release version.
I can reproduce the problem on my side. Need to check the EZ-Serial FW and reply you later.
Can you give me an answer?
TK
