KeTa_1341526
10 likes received 5 likes given First like given
I am investigating Bluetooth Classic (BR/EDR) Secure Mode of EZ-Serial F/W.
https://www.cypress.com/file/452971/download
- Security Mode 4 (service level enforced security)
  => Secure Simple Pairing
       (1) Just works: EZ-Serial F/W is supported.
       (2) Passkey Entry: EZ-Serial F/W is supported.
       (3) Numeric Comparison: EZ-Serial F/W is supported.
- Security mode 3 (link level enforced security) & Security mode 2 (service level enforced security)
  => Legacy PIN mode: EZ-Serial F/W is supported.
As mentioned above, it seems that Security Mode 4-2 can be supported.
But I don't know how to work with Security mode 1 (non-secure).
Does EZ-Serial F/W support Security mode 1 (non-secure)?
Takahashi
Which mode do you need in your application?
If you need pairing and bonding in your application, you must use the secure mode.
Because of the following errata, non-secure mode is not suggested for your product. Security Bulletin: Public Statement on Bluetooth SIG Member Statement on Bluetooth Impersonation Att...
AnjanaM_61
First comment on KBA 5 questions asked First question asked
Hi KeTa_1341526
You can set the security parameters using smp_set_security_parameters
No Security should be set by setting the mode parameter of above as 0x10
Anjana
Hello AnjanaM_61,
Which parameter sets 0x10?
SSBP seems to have M (mode) and F (flags).
Is it meant to be set to either?
I am referring to P.145 of the following new User Guide.
I think the following is how to set each mode.
      SSBP, M=40,B=1,K=10,P=0,I=3,F=1
      SSBP, M=40,B=1,K=10,P=0,I=2,F=3
      SFPK,P=1E240
      SSBP, M=50,B=1,K=10,P=0,I=0,F=3
(4) Legacy PIN mode: EZ-Serial F/W is supported.
      SSBP, M=40,B=1,K=10,P=0,I=0,F=5
      SBTPIN, P=30303030
(5) Non Secure
However, I do not understand the Non-Secure mode setting in (5).
Non-Secure mode is the recognition that it is a mode that does not perform pairing.
Takahashi
