LiLe_3234306
25 replies posted First comment on KBA 50 sign-ins
First of all, I am using like as for test environments.
- EVK : CYW920721EVK-01
- SDK : WICED SDK 6.2.1
- Application : snip.gpio
I'd like to download application in command line(not IDE tools). So, I generated script by using VERBOSE=1 option in make target.
However, when I download "snip.gpio" application with script generated by VERBOSE=1 option, download is always failed.. Please refer to attached image for error information.
As you can see,  "ChipLoad.exe" and "snip.gpio" application, minidriver, btp file are copied into same folder as batch file(a.bat). However, "DownloadMinidriver" is always failed when I try to download with generated script.
Surely, download is working well with IDE tools. Could you check it?
Liam
SheetalJ
Hi Liam,
CYW20721 is not a broad-market chip, so not supported here on Cypress Community. Please contact your local Cypress team to get more support on this.
However, links at this thread might help regarding Chipload downloading issue: Re: chipload user's guide
SheetalJ
Hi Liam,
Hi SheetalJ_96,
This is Liam.Lee working for Uniquest(Korea Disty) as FAE. As you asked, I'll open MyCase for this asking.
Liam
