Nov 09, 2021
01:01 AM
Nov 09, 2021
01:01 AM
I'm using the CYBT 423028-02 on your evaluation board with EZSerial 1.0.4.21 installed.
When I try to connect to a device that prefers 2M Physical Layer I will be disconnected after a short while and I'm also unable to discover any services until the disconnect.
When I force the client to use 1M Phy instead everything works stable....
So I'm wondering if EZSerial does support 2M Phy?
Alex
Labels
WICED Studio Bluetooth
01:14 AM
Nov 11, 2021
01:14 AM
2M PHY is not supported by EZ-Serial yet.
You can use a sniffer/probe to confirm if the device supports 2M PHY.
