mawu_4270096
5 sign-ins First like received First like given
Hi:
I use the CyBluetool to download firmware. unlucky the  firmware  has not been successfully burned.
I guess  if there is any bug for the burning software
I suggest that you use the wiced studio to download your application. Otherwise, you can also explore the chipload.exe method.
Do revert if you have issue with these methods.
Owen_Zhang123
500 solutions authored 250 sign-ins 1000 replies posted
Could you let us know which device are you using?
Please refer to the following screen capture to download firmware to 20706:
You may need to do the recover procedure if download failed.
mawu_4270096
Hi  OwenZ_26:
      my hardware platform is CYW20735.  if the CyBluetool can't  surpport the CYW20735 firmware burning!
Are you using a module or CoB? What is the HW setup you currently have for downloading?
mawu_4270096
Hi  BooT_56:
    I  use the CYW920735Q60EVB-01 board  to download firmware .
