Hi KeSh_4337371,
hex file gets created in Build folder along with hcd file after you build the project. You can convert hcd to c using hcd2c.pl script available in WICED. Please refer comments in /43xxx_Wi-Fi/apps/snip/bluetooth/ble_hello_sensor/ble_hello_sensor.mk for more details.
Hi KeSh_4337371,
Hi, What does that mean, "to c" ?
Language c ? the hcd file canbe converted source code written by c ?
Th conversion will be from hcd file to byte-array in a .c file.
the hcd file is used to inject only data, not code section ?
Sorry I dint get you.
hcd file is the final downloadable file which contains all the source,library,ROM patches, configuration information after compiling.
I have understand why you mentioned the hcd2c.pl. But i'd like to know structure of the hcd. As i see, there are something based on ELF format. Can you share about that information ?
Please check software section in https://www.cypress.com/documentation/application-notes/an226546-cyw20819-feature-and-peripheral-gui...
