CoCo_1816446
Level 4
Level 4
  Currently, I use something like this: WPRINT_APP_INFO( ( "wiced_bt_ble_set_advertisement_data %d\n", result ) );
that would output the following to the terminal: "wiced_bt_ble_set_advertisement_data 0"
Then I have to figure out what the value 0 represents in the enum where it's declared.
Is there a function that could convert the numerical value back to the string its equal to?
I would like to see something like this: "wiced_bt_ble_set_advertisement_data WICED_SUCCESS"
DheerajPK_41
wiced_bt_ble_set_advertisement_data will be returning the decimal or Hexadecimal value to indicate the results. See wiced_result.h.
It is not recommend to modify this header file, because it may break other applications.
I would suggest you to create another custom list for your application which will return the string instead of the value of the results.
-Dheeraj
DheerajPK_41
-Dheeraj
