KaRe_1495521
First like received
I followed this tutorial to configure ClientControlMesh.exe on my Windows10 laptop, Cypress BLE Mesh Solution
I downloaded mesh_provision_client firmware on my CYW920719Q40 EVK.
In section "Provisioning using windows ClientControlMesh Application", step 3 Click the "Open" button.
I always had below issue, how can I solve this problem?
SheetalJ
Can you specify the WICED version you are using?
Meanwhile, you can try opening the ClientControlMesh.exe from the installed folder.
I am able to open the application on my system in both WICED SDK 6.1 and 6.2.1.
SheetalJ
Yes, you're correct, when I open this app, ClientControlMesh.exe from the installation folder, it works well!
Thanks!
