YoJa_3107936
50 sign-ins First like given 100 replies posted
Hi everyone
The customer purchased the CYW920721B2EVK-02 Evaluation Kit.
Which application should they use on Modus if they want to evaluate another application and then return it to the factory state?
If you don't provide the source code, can you tell us how to get back to the initial state?
Yang
Charles_Lai
250 replies posted 100 solutions authored 100 replies posted
If you need the demo code showing the headset functions, you can burn the demo called "Audio Headset and Speaker". You can find it within ModusToolbox Project Creator or the link below:
https://github.com/Infineon/mtb-example-btsdk-audio-headset-speaker
We don't have a definition of "factory state" upon this kit. Though it could be shipped with some default functions loaded.
Charles_Lai
Try to burn the empty BTSDK app to the device. You can find it within ModusToolbox Project Creator or the link below:
https://github.com/Infineon/mtb-example-btsdk-empty
Thank you for your answer.
The empty BT SDK was written when this evaluation board was shipped.
Is this recognition correct?
Yang
The source code you contacted is the same as the firmware written when the EVK was shipped.
It doesn't look like the source code that works as a headset.
Hi
How is this case going?
Yang
Charles_Lai
