daba_4649501
10 replies posted 5 replies posted 5 questions asked
gfreenetamAnjanaM_61MichaelF_56DaZh_2976111
i am using CYW920719Q40EVB-01 kit and i'm using WICED studio 6.4.0.61 IDE for software development.
when i try to download a demo project(hello sensor)or snips , it can build successfully but it does not getting download in the board
it says
Detecting device...
| No CYW207x9 device detected.
| 1. Verify the CYW207x9 WICED eval board is connected _AND_ powered
| 2. Verify all switches are set to the default positions
|    - see "Connect the WICED Evaluation Board" in the Quick Start Guide or Kit Guide
|      for defaults
| 3. Press the reset button on the WICED eval board and retry
| See 20719-B1_Bluetooth/README.txt for more info.
| If this problem persists, the board EEPROM may need to be reset to factory defaults.
| Please see Recovery instructions in the Quick Start Guide or Kit Guide.
i have tried the recovery and resetting options in the board but it still does not working. when i check the device manager it shows all the drivers are installed but still not downloading.
please help me to resolve this issue.
thanks and regards
Danny.
Message was edited by: danny baker
Hi daba_4649501 ,
Yes , seems to be like some issue with board. Please try with a new one. Hope you are able to do download FW to your CYW20820 Eval board without any problem.
Also please note, the latest 20719 version is 20719B2 https://www.cypress.com/documentation/development-kitsboards/cyw920719b2q40evb-01-evaluation-kit  . For new customer application, we recommend to use 20719B2.
Note:
Meanwhile I would suggest you to go through our WICED Academy files for getting started : GitHub - cypresssemiconductorco/CypressAcademy_WBT101_Files: Files for WICED Bluetooth 101 class
Anjana
