makuc_4236116
we have the above board and dont find a document which explains how the Jtag interface must be activated.
I get the error:
J-Link GDB Server failed:
Could not connect to target. Please check if target is powered and if ribbon cable is plugged properly.
For more details, see the JLinkGDBServerCL.exe console.
I found the document CYW207x9-JTAG-Debugging but this is not exactly the board which I have. In the document
is mentioned that in the code something must be changed to activate the gpio.
My question now:
Can it be that I have this problem? Must something be done in the code to activate the J27 Header?
Manfred
AnjanaM_61
First comment on KBA 5 questions asked First question asked
Hi Manfred,
Could you please confirm if you gone through the doc 'Debugging-Support-Using-J-Link.pdf ' available in the doc folder of WICED SDK (  /20706-A2_Bluetooth/doc/Debugging-Support-Using-J-Link.pdf  )
Attached the same.
Anjana
AnjanaM_61
Hi Manfred,
Attached the same.
Anjana
