I need to change the frequency of I2S_PCM_CLK but I don't understand how.
The frequency that i need is at least 1024KHz but at default is 256KHz.
I don't find anything I2S driver in the wiced studio to do this.
I have a I2S Output Digital Microphone SPH0645LM4H-B that doesn't work at the default 256KHz.
Hi Stefano,
I am not sure if the SPH0645LM4H-B will be compatible with CYW20706.
Because CYW20706 uses 16 bit data formatting where as SPH0645LM4H-B datasheet says 24 bit data format.
Anjana
Could you please confirm which profile are you planning to use? Whether A2DP or HFP?
HFP
Hi Stefano,
Anjana
