Dear Cypress
I want to know if there is a way to play the tone through I2S.
As an example, when a user presses a button, I want to output pre-defined wav data to I2S.
Please refer to below for detailed conditions:
- H/W : CYW920706WCDEVAL
- S/W : It doesn't matter if it is WICED or MODUS
Thanks in advance.
ispn:38625:1:0
l1:314:1:0
I do not see a direct implementation of your required application. Since it is a bluetooth chip, the applications are more focussed on the bluetooth functionality.
A similar implementation you will be able to see in the below application where the SCO packets routed to PCM/I2S.
https://github.com/Infineon/mtb-example-btsdk-audio-handsfree
In the below application, the .wav file is transmitted from the ClientControl to the BT chip via UART.
https://github.com/Infineon/mtb-example-btsdk-audio-watch
-Dheeraj.P.K
Dear Cypress
Thanks for your help.
BR, Romeo
