YoJa_3107936
Distributor - Macnica (Japan)
100 sign-ins 50 sign-ins First like given
Hi
Could you list the encryption key name and key length for CYW20819?
AES 128bit is described on the data sheet.
Is BT E0 128bit also available?
Please tell me everything else.
Yang
Roy_Liu
5 comments on KBA First comment on KBA 10 questions asked
Sorry, nobody from logistics department working in this Developer Community, would you please create a "Customer Service" mycase where you could get support for this matter? The other option is contacting your local Cypress sales office.
Roy
Roy Liu
Owen_Zhang123
5 questions asked 500 solutions authored 250 sign-ins
Why do you have the question? What's the application scenario?
Is it for BLE or BT?
You may refer to the parameter wiced_bt_device_sec_keys_t in wiced_bt_dev.h.
YoJa_3107936
We will submit the parameter sheet to the customer.
It is necessary to describe in the parameter sheet.
Should not be checked on the source code.
Which encryption key do you refer to? There are many keys during the BLE and BT connection/data transfer. They are defined in the bluetooth spec.
YoJa_3107936
Thank you for your cooporation.
Sorry, I think this is not a technical issue and is related to logistics, so please assign a person in charge of export control.
I think they know what to fill in.
Roy_Liu
Roy
Roy Liu
