I've been dealing with this strange problem since starting out on the CYW20719: declaring a global variable of class type leaves it uninitialized and unusable.
if I have this code for example in main.cpp:
class A {
public:
A(int val) : a(val) { WICED_BT_TRACE("A()"); }
int a;
A a = A(5);
APPLICATION_START() {
WICED_BT_TRACE("%d\n", a.a);
The constructor of A never actually gets called. How can I fix this?
Thank you,
Nicholas
Hi Nicholas,
Currently the WICED SDK does not fully support C++ and also we do not have any plan to support C++ in near future.
-Gyan
