i used the API of "wiced_hal_write_nvram" for write to nvram about 132byte.
but, sometimes it is fail with 0x004 error code.
my code is as below.
bytes_written = wiced_hal_write_nvram( 0x01, sizeof(setting_t), setting, &result);
and if i use the API "wiced_hal_write_nvram" for write to nvram, result is repeat as below.
save_setting(result: 4, written: 0)
save_setting(result: 0, written: 132)
where is the result of API of "wiced_hal_write_nvram"?
i want to know what is mean the result is 4. could you help me?
Hello @hyhw_4628441
As liam suggested, did you get a chance to test your code on our EVAL board? where you able to reproduce the problem on our EVAL board?
If problem exists only on your custom board, can you please provide us the details on which flash you are using ? Also suggest you to have a schematics / PCB review.
Anjana
