JaSi_1632926
Level 4
Level 4
When using CYW20706 in A2DP sink mode:
- How many paired peers does it support?
- How many concurrent A2DP connections does it support?
Thanks, Jacob
Owen_Zhang123
500 solutions authored 250 sign-ins 1000 replies posted
The paired information is stored in the NVRAM, there isn't a limit for the number of the paired peer devices. In the A2DP sink demo, it stores only 1 paired information. You may refer to the audio_gateway demo which can store multi paired information.
For A2DP, it can only support 1 connection with audio streaming. For A2DP connection without audio streaming, we only tried 2 connections.
Owen_Zhang123
If I have two active connections (one of them streaming), are they affected by advertising?
Thanks, Jacob
The stack will process the logic. It will be OK to have two connections.
