I have a question about "user_data" parameter in interrupt handler.
In the prototype of wiced_hal_gpio_register_pin_for_interrupt() API, 3'rd param(void *userdata) is "Will be passed back to userfn as-is". However, when I test it with following test code, it looks not working. I guessed "udata" must be printed out "123" but printed out "168". I am not sure if my test code is incorrect or it's SDK bug.
Q) May I ask what's wrong with following test code?
H/W : CYW920706WCDEVAL
S/W : WICED SDK 6.4.0
void headset_set_input_interrupt(void)
uint8_t my_data = 123;
wiced_hal_gpio_register_pin_for_interrupt( WICED_GPIO_BUTTON, headset_interrupt_handler, (void *)&my_data );
wiced_hal_gpio_configure_pin( WICED_GPIO_BUTTON, WICED_GPIO_BUTTON_SETTINGS( GPIO_EN_INT_BOTH_EDGE ), WICED_GPIO_BUTTON_DEFAULT_STATE );
void headset_interrupt_handler( void *user_data, uint8_t value )
WICED_BT_TRACE("[%s] enter...\n", __FUNCTION__);
if ( wiced_hal_gpio_get_pin_input_status(WICED_GPIO_BUTTON) == BUTTON_PRESSED )
WICED_BT_TRACE( "Button pressed\n");
else
uint8_t udata = (uint8_t *)user_data;
WICED_BT_TRACE( "Button released\n" );
WICED_BT_TRACE( "udata = %d\n", udata);
Liam
WICED Studio Bluetooth
- interrupt handler
We need to check the problem internally. You may use a global variable for it as a workaround.
Hi Owen,
Understood.
Liam
