I am following the "CYW920706WCDEVAL Kit Guide" to view the traces on the windows with Bluetooth application Hello Sensor
I had followed "4.4.2 View Traces Using a Terminal Emulation Program" with no problem.
However, When I tried to view the traces using the BTSpy (4.4.3 View Traces Using the BTSpy Windows Application), I could not see trace messages. The Client Control and BTSpy displayed these and no more:
16:45:43.762 Opened \\.\COM46 at speed: 3000000 flow on
16:45:45.753 Startup
16:45:45.753 Set discoverable:1, connectable:1
16:45:45.753 Set Pairable:1
The Bluetooth application is built and downloaded and works well.
ispn:38625:1:0
l1:314:1:0
- cybt343026-01
Hi JiYa_3557771
Please note, for CYBT 343026 , you have to select 115200 baud rate for HCI UART in Client control.
Then only you will get BTSpy traces correctly.
Anjana
