MaMi_1707981
Level 6
Level 6
500 replies posted 50 solutions authored 250 sign-ins
According to the DATA sheet of CYW-20706,  Left-channel data is transmitted when I2S WS is low, and right-channel data is transmitted when I2S WS is high. Is it correct ?
Our customer says the opposite result is observed.
[Envorinment]
    CYBT-343026-01
    WICED Studio 6.2
    Profile/role: A2DP/source
    Peer devices: at least two products. One is LBT-PAR500 made by ELECOM.
Hi Xinghao,
Thank you for supporting.
I contacted a local FAE.
This issue will be fixed.
Mizuno
Owen_Zhang123
500 solutions authored 250 sign-ins 1000 replies posted
The description in the datasheet is correct.
Could you let us know how does the customer observe the error?
HOST sends L-channel only data, i.e. all '0' for R-channel.
Then,  we check it on peer device(A2DP sink headset).
Does the host act as I2S master? Did the customer check if the host sends data in right format?
The host acts as I2S master. CYW20706 acts as I2S slave.
It looks I2S format is correct.
According to the custommer's report,  the audio stream is sent correctlly except L/R channel is wrong.
Please find the attached log.
It is a signal wave when only L channel is sent.
Could you double check it ?
Hi Xinghao,
Mizuno
