Oct 22, 2018
12:34 AM
Oct 22, 2018
12:34 AM
According to AN91445,there is antenna radiation pattern in P.13.
AN91445: http://www.cypress.com/file/136236/download
Q1: Is PCB antenna of CYBT342036 the same specification?
Q2: How long does the customer need to separate from screw hole?
Thank you.
--TAK
10:37 PM
Nov 07, 2018
10:37 PM
Hi Tak,
Antenna spec is documented in 343026 datasheet. Table 6
As for antenna pattern, we don’t test antenna pattern based on specific module. In fact the antenna pattern will change in end product. This module uses Cypress qualified PCB Nano antenna and we don’t have 3D antenna pattern.
Anjana
