I am using a CYBT-423028-EVAL. I have set up the platform files per KBA223637
WICED Studio: Platform Files for CYBT-423028-EVAL - KBA223637
I created a new make file demo.hello_sensor-CYBT_423028_EVAL download
When I build, I get the following error that the CYBT-423028-EVAL is not found:
I verified that the Eval Board is recognized in Device Manager and the driver is working.
Any suggestions are appreciated.
Please try to program the KIT under recovery mode.
To put the device in recovery mode, press the recovery button, press and release the RESET button, then release the recovery button. Then try to program the module again.
You may refer to the following KBA for details: Programming an EZ-BT WICED Module – KBA223428
