CYBT-413034 PUART flow control
ilHw_4713311
Level 4
Level 4
5 solutions authored 50 sign-ins 50 replies posted
How I can configure puart flow control?
I made two changes but it did not work well.
one
const wiced_platform_gpio_t platform_gpio_pins[] =
        [PLATFORM_GPIO_4 ] = {WICED_P06, WICED_UART_2_RTS        },
        [PLATFORM_GPIO_5 ] = {WICED_P07, WICED_UART_2_CTS        },
two
wiced_hal_puart_flow_on();
Please let me know how I can make it.
In my test, CYBT-413034 made compile error wiced_hal_puart_select_uart_pads
I changed my target UART control setting and I could use PUART flow control.
Thanks!
DheerajPK_41
Did you select the Tx,Rx, cst,rts pins for the UART hardware using wiced_hal_puart_select_uart_pads() ?
BOOL32 wiced_hal_puart_select_uart_pads(UINT8 rxdPin, UINT8 txdPin, UINT8 ctsPin, UINT8 rtsPin);
How did you implement the flow control in your application? May I know the code flow?
Please attach the PUART code snippet here, if possible.
-Dheeraj
Thanks!
