CYBT-353027 NVRAM read error
MaDu_3290941
First like received
Hi Cypress,
I'm trying to use the NVRAM to store the pairing keys on a CYBT-353027 Eval board using Hello Client project but it doesn't work.
I have added APP_PATCHES_AND_LIBS += FM25Q04_sflash.a in the makefile of my project as requested in the installation process.
It seems that the write NVRAM command works but if I try to read it again the Read NVRAM function returns 4 which is not documented.
-----> My assumption would be that the write NVRAM doesn't work.
I found in the forum that on Wiced smart, there was an api to handle the write protection, is there something similar for Wiced Studio?
Here are the logs:
hello_client_app_init
wiced_bt_gatt_register status 0
wiced_bt_gatt_db_init 0
hello_client_management_cback: 17
Advertisement State Change: 3
wiced_bt_start_advertisements 0
1
2
3
4
5
6
7
8
9
10
hello_client_gatt_callback event 0
hclient_connection_up Conn Id:1 Num conn:1,Addr:<7f 22 c6 9f 4c 50 > role:1
Advertisement State Change: 0
hello_client_gatt_callback event 4
hello_sensor_gatts_req_cb. conn 1, type 5
peer mtu:185
hello_sensor_gatts_req_cb. conn 1, type 1
read_hndlr conn 1 hdl 42
read_hndlr conn 1 hdl 44
11
read_hndlr conn 1 hdl 46
read_hndlr conn 1 hdl 62
hello_client_management_cback: d
hello_client_management_cback: a
hello_client_management_cback: 12
--------------------------------------------------------FIRST PAIRING---------------------------------------------------
Read NVRAM at:1 bytes:0 result:4              // Can't read NVRAM, return 4 which is not documented
writing to id:1
Saved 138 bytes at id:1 0                            // Seemed to have saved the pairing key
hello_client_management_cback: b
Pairing Complete: 8
12
read_hndlr conn 1 hdl 16
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
hello_client_connection_down 1 <7f 22 c6 9f 4c 50 >
wiced_bt_start_advertisements: 0
29
30
31
32
33
34
35
-----------------------------------------------------------------RESET DEV BOARD--------------------------------------------------
áhello_client_management_cback: 15
hello_client_management_cback: 14
hello_client_management_cback: 0
1
2
3
peer mtu:185
4
5
6
7
hello_client_management_cback: c
--------------------------------------------------------TRY TO RECONNECT ---------------------------------------------------
encryption status: bd ( 7f 22 c6 9f 4c 50  ) res 0
hello_client_encryption_changed 0hello_client_management_cback: 12
Read NVRAM at:1 bytes:0 result:4                      // Can't read the NVRAM at he exact same id as it was supposed to be saved in the previous connection
Delete id:1 Result:8109
writing to id:1
Saved 138 bytes at id:1 0                                    // Write the pairing key at the first Id as done during the previous connection
Pairing Complete: 0
read_hndlr conn 1 hdl 2b
8
9
10
I tested the NVRAM write with WICED 6.1 on CYBT353027. I add some log to print the bonded device in the BTM_ENABLED_EVT. After bonded two device, the bonded device address can be read successfully after reset of the module. Below is the trace log:
[18:35:1:989] Z
[18:35:2:4] 穁簵
[18:35:2:139] hello_client_management_cback: 15
[18:35:5:539] hello_client_gatt_callback event 0
hclient_connection_up Conn Id:1 Num conn:1,Addr:<bc 20 10 12 09 6d > role:1
[18:35:6:338] hello_client_management_cback: c
encry
[18:35:6:360] ption status: bd ( bc 20 10 12 09 6d ) res 0
[18:35:6:632] hello_client_management_cback: 12
R
[18:35:6:647] ead NVRAM at:1 bytes:0 result:4                  // First device bonded
writing to id:1
[18:35:6:663] Saved 138 bytes at id:1 4
[18:35:6:680] b
Pairing Complete: 0
hello_client_management_cback: 1f
[18:35:13:910] hello_client_management_cback: 1f
[18:35:14:437] hello_client_gatt_callback event 0
[18:35:14:464] hello_client_connection_down 1 <bc 20 10 12 09 6d >
[18:35:19:24] hello_client_gatt_callback event 0
hclient_connection
[18:35:19:56] _up Conn Id:1 Num conn:1,Addr:<18 59 36 ff ea 1e > role:1
[18:35:19:312] hello
[18:35:19:328] _client_management_cback: 1f
[18:35:19:918] hello_client_management_cback: c
encryption status: bd ( 18 59 36 ff ea 1e ) res 0
[18:35:20:213] hello_client_management_cback: 12
Read NVRAM at:1 bytes:138 result:0                       // second device bonded
Read NVRAM at:2 bytes:0 result:4
writing to id:2
[18:35:20:228] Saved 138 bytes at id:2 4
hello_client
[18:35:20:249] _management_cback: b
Pairing Complete: 0
[18:35:27:464]
// module reset
[18:35:27:842] Z簵
[18:35:27:938] h
[18:35:27:991] ello_client_management_cback: 15
Updated Addr Resolution DB:0
bonded device address is: bc 20 10 12 09 6d  //read the bonded devices infromation
bonded device address is: 18 59 36 ff ea 1e
I also attached the project I used for your reference.
AnjanaM_61
5 comments on KBA First comment on KBA 5 questions asked
Could you please let us know Which version of the SDK you are using?
Anjana
anpm
I'm using SDK 6.1.
I tried to move to 6.2 but the installation failed on my Ubuntu machine. No solution yet in the forum:
https://community.cypress.com/message/176629?et=watches.email.thread#176629
[18:35:1:989] Z
[18:35:2:4] 穁簵
encry
R
writing to id:1
[18:35:6:680] b
Pairing Complete: 0
hclient_connection
writing to id:2
hello_client
Pairing Complete: 0
[18:35:27:464]
// module reset
[18:35:27:842] Z簵
[18:35:27:938] h
