SaEa_4705941
25 replies posted 10 replies posted 10 questions asked
Hi members,
I am new to this community and Cypress module. Looking for a starting guide to create my first project to send and receive commands from a host mcu.
Se
AnjanaM_61
First comment on KBA 5 questions asked First question asked
Hello saea_4705941 ,
There is no getting started appnote specifically for CYBT-343151. However you can refer the getting started appnote here : https://www.cypress.com/documentation/application-notes/an223400-getting-started-ez-bt-wiced-modules  . In the guide , it uses 343026 module which has a same base chip of CYW20706.
Please use the platform files available here: Platform Files for CYBT-343151-EVAL – KBA226799
Anjana
AnjanaM_61
Anjana
Hi Anjana,
Thanks for the urls for documents.
according to this​ document, there is no explicit way to set a custom/exisitng pass code for bluetooth authentication. Please clarify whether this module is capable of setting custom pass codes for pairing in BR/EDR mode.
And also does this module allows transmit power control? If not what would be the default tx power in BR/EDR mode?
Se
Hi saea_4705941 ,
Yes, You can't use custom passcode. You have to use the one generated from stack.
Please also refer thread - CYW20706 Pairing mode
You can set the Tx power within the maximum limit as described here :Configuring Transmit (Tx) Power on CYW20706 Chip - KBA228573
Anjana
Hi AnjanaM_61,
Thanks for clarifying.
I have few more questions and posted then as a separate discussion. Thanks for your support.
Kind Regards,
Se
Sure!
Anjana
