ducac_3894946
i have used the CYBT-343026's platform: Platform Files for CYBT-343026-EVAL – KBA221025
and i cannot get the Evaluation module to connect to the WICED Studio.  The error i received says that it actively refused connection (basically no connection to EVAL).
i am trying to program either the uart.hex or the app/hello sensor application.  Any advice?
Owen_Zhang123
500 solutions authored 250 sign-ins 1000 replies posted
Could you refer to the following KBA to see if it can help: Programming an EZ-BT WICED Module – KBA223428
You may program the kit under a recover procedure.
Owen_Zhang123
Thank you yes i have been using this KB however i did not look at a recovery procedure.
I will research that and see if i can recover it.
Thank you
