GHKC
10 replies posted 10 questions asked 5 replies posted
hii Madam/sir,
     Currently i am working on cybt-343026 module. For Testing purpose  spp(example project) downloaded into cyw920706 evaluation board it is working as expected then same program i downloaded into cybt-343026 module through cyw920706 evaluation board. But after downloading sucessfully module not advertising.
                                            can any one give solution for this.
SheetalJ
Hello HaGo_4718696​,
>>I did not understand what do you mean by this.
I would suggest you to try demo.hello_sensor example first. Use the Make Target to download default example to CYBT343026 eval board
demo.hello_sensor-CYBT_343026_EVAL download UART=COM39
where COM39 is the HCI UART port.
You should be able to see the hello sensor advertising in your mobile/laptop using CySmart or any other bluetooth application.
SheetalJ
