Hi
We want to confirm the operation of test command from PC to the evaluation board.
If we don't implement OPEN_PORT on ClientControl,
Even we send the test command from PC to tne board,
we confirmed that the board don't send the ACK signal to PC.
Do we have to implement OPEN_PORT on ClientControl, if we want to let that the board send the ACK signal to PC.
Y.Jiang
Hi jiang-y_3107936,
PC will not recognize the board unless you select 'OPEN PORT' in ClientControl after selecting the correct COM port.
You need to implement OPEN_PORT on ClientControl.
Hi jiang-y_3107936,
